Home › Forums › Public Support Forums › Spare Parts Help › Homark Oven Door
- This topic has 6 replies, 4 voices, and was last updated 21 years, 6 months ago by
admin.
October 2, 2004 at 8:24 pm #6395
KeymasterDoes anyone know where I can get hinges for the door of a Homark fitted oven.
The model number is 05-903107Prod No. 3203123-190
October 2, 2004 at 11:45 pm #117438Penguin45
ParticipantDC should be able to help you out with that one on Monday.
Penguin45.October 4, 2004 at 8:26 am #117439Dave_Conway
ParticipantRe: Homark Oven Door
Two things here:
The model you have provided is a 90cm range cooker not a fitted/integrated oven, could you please confirm.
If the model is correct, there are two versions, one pre 2001 and the other 2001 onwards so I would need the serial number as well, the hinges are different on both model versions.
Regards.
October 5, 2004 at 1:18 pm #117440admin
KeymasterRe: Homark Oven Door
Thanks Dave.
Yes this is a 90cm oven.
I will need to get back to you on the serial number – can you help with where I am likely to find that.
That said I’m pretty certain that I bought the kitchen and cooker over 4 years ago which would make it pre 2001.
October 5, 2004 at 3:16 pm #117441Dave_Conway
Yep, sorry the description I have is incorrect, it is built in as you rightly say, not many 90cm built in ovens about mind you 😉
Serial number should be around the door, although, if the kitchen is 4 years old then the oven will be at leasy 6 months older than that so it’s almost certainly the earlier version.
The hinges for this version are £13 each inc VAT, plus about £5 postage. Please be aware though, this is a Nardi manufactured oven and the parts can take weeks to arrive 🙁
If you want them ordered, let me know by email and I’ll let you have further details.
April 13, 2006 at 8:27 pm #117442Slash
having Google searched for Homark oven doors for a 903107 90cm oven I found your messages from Oct 2004. Can you please tell me if these hinges are still available? The oven product number is 3443123.190 and F.Nr 038 8 059Slash
April 13, 2006 at 9:58 pm #117443Dave_Conway
Slash wrote:Can you please tell me if these hinges are still available?
Yep, they are 😀
Part number 031199009909R at £15 each inc VAT plus carriage.
An email to spares@ukwhitegoods.co.uk please if required
