Homark oven help
  • #49586
    topconker
    Hi, just found and joined the forum and looks like there’s a whole wealth of information to be had.
    We’ve just moved into our new home and have a Homark double oven fitted in the kitchen.
    All works well apart from the grill, that is controlled by the centre knob of three and when I turn it on I notice the red warning light does’nt come as it does with the fan oven or top oven.
    Can anyone help as I dont have a manual.
    Many thanks for any help,
    TC
    #300338
    washermanuk
    Re: Homark oven help
    Hi! just check your top oven control knob, on some cookers you need to turn this to grill function then set temp? which would be the one your trying to use.
    hope this is useful
    Brian
    #300339
    topconker
    Thanks Brian,
    Had a look but there’s nothing on the dial to idicate a control for the grill.
    Looking at the top of the oven fro left to right are the following:
    window with clock and timer in it beneath which are the 2 small knobs to set time and timer.
    In the middle a small red light that iluminates when I turn on eith either the fan oven or conventional oven .
    Next is a control knob for the conventional oven that when turned on first lights the oven bulkb and the small red indicator then sets the heat level.
    Next there is the grill control knob and when I turn it on, the small red light doesn’t go on and the grill doesn’t work.
    Lastly there is the fan oven control knob that again, when I turn it on the small red light comes on and I set the temperature with it.
    Incidentally, when I turn on the top conventional oven the grill element works.
    Hopefully you may be able to help me, although thinking about it, it may be the control knob that’s faulty rather than the element.
    Many thanks,
    TC
    #300340
    Washman
    Model number would be a great help.
    Washman
    #300341
    topconker
    Sorry Washman, cant find a serial number anywhere as the oven is built in and I guess any number is on the back somewhere.
    I’ve looked inside both the conventional oven and the fan oven and cant see anything.
    TC
