Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Homark Oven User Manual
- This topic has 124 replies, 63 voices, and was last updated 20 years, 4 months ago by
Nic007.
April 29, 2006 at 10:04 am #155958
ACS76
ParticipantRe: Homark Oven User Manual
Glad I’m not the only one have problems with my Homark. It is a white fitted oven MOD. 02-7600 TYP. FEM 1375 – same problems apply i.e. new house, no manual, dials have faded, oven doesn’t work unless timer on and not sure if there’s a grill?? I would be grateful for any help,
Many thanks
AlexApril 30, 2006 at 2:04 pm #155959Dave_Conway
Could you check the model number ACS76 – 02-7600 isn’t long enough, there’s two more number (probably on the end after the zeros).
May 1, 2006 at 9:08 am #155960ACS76
Hi Dave,
Have just checked but there are no more numbers after 02-7600 – just the word WHITE. The only other details are:
SNr. 6351560000-710887
230V – 50Hz
2,15 KW max.Hope this helps!
Kind regards
AlexMay 2, 2006 at 1:31 pm #155961Dave_Conway
In that case it’s very old, can you describe the knob positions and any timer on the control panel, I’ll try and find something close.
May 3, 2006 at 2:18 pm #155962ACS76
Hello,
Knob positions from left to right are: Timer, temperature control and settings. the settings dial has 5 symbols including: lightbulb, two horizontal lines, fan, fan with 3 triangles above and fan with horizontal line underneath. Hope this sheds some light!
AlexMay 3, 2006 at 9:31 pm #155963Dave_Conway
One sent by email Alex, the closest I can find 😀
May 4, 2006 at 7:07 pm #155964ACS76
Many thanks 🙂
May 8, 2006 at 7:32 pm #155965boople
ParticipantMay 16, 2006 at 6:11 pm #155966sssassyangel
Hi Dave
Hoping you can help me with manual for Homark too! Haven’t been able to use grill at all but now even worse……. 😥
I took the oven door off to clean it and now can’t work out how to get it back on!
It’s Model 02-700400 typ B11 and has 3 knobs, one on left for timer and two on right.
ThanksMay 16, 2006 at 6:15 pm #155967Penguin45
While Dave sorts a booklet out, you might wish to check this:
http://www.ukwhitegoods.co.uk/modules.p … pic&t=3771Gives a pretty fair idea of how most oven doors are fitted.
Penguin45.May 16, 2006 at 9:03 pm #155968sssassyangel
Thanks Penguin but it’s slightly different. 😥
May 16, 2006 at 9:15 pm #155969sssassyangel
I may not be able to use it but hey, at least I’ve got a beautifully shiny oven on show to the world! 😉
May 17, 2006 at 11:55 am #155970Dave_Conway
Manual on the way sssassyangel but it doesn’t show how to remove and replace the door 🙁
The videos that Penguin pointed to should be near enough though 🙂
June 1, 2006 at 2:29 pm #155971lainey24
Hi I have a similar problem, moved into new house homark cuisine built-in oven but no idea how it works. Cant read dials and model numbers etc have all been worn off!!!! Please could you help, it is white with small window with cover on the front, has three dials from the left side, the first is a timer then temp and then functions. Hope this helps
Lainey
June 1, 2006 at 6:02 pm #155972Penguin45
The model number is still on a label on the oven roof….
