Re: Homark oven – which model is it?
ade the staining is normally due to heat being vented thru the handle grills… BUT id agree the hinges look a bit worn as the door portrudes from the fascia slightly.
looks very much like a whirlpool, and if its only fan assisted, rather than a circular fan oven, then the dual circuit grill (which it prob is as its a homark) will be between £35-55, this is ovbiously assuming its even a fan oven, it could well be static.
single ovens are so cheap these days, if it was my customer id suggest replacing it with a bosch hbn331w0b, hotpoint sy36w, or if you are on a budget, and dont want a clock, a beko oif21100w
