Hood problems – Hygena APP2130
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Hood problems – Hygena APP2130
  • #35836
    barnacleben
    I have some problems with my cooker hood which has not worked since we have moved in. The light works, but when I switch the fan on all I get is a buzzing sound and it doesn’t go round. I guess it is the motor that has gone. Does this make sense and is it easy to replace?
    Cheers
    Ben
    #248323
    Dales-Electronic
    Re: Hood problems – Hygena APP2130
    Not too difficult – power off remove 1 black screw from motor cover and turn thro 15 degrees motor and cover will drop down. Remove and replace with supplied new motor. However, you will probably find that a new hood is cheaper than the motor.
    #248324
    Two possible culprits Ben…
    The PCB/switch assembly
    Or…
    The motor itself
    Motors do fail, but it’s more likely the PCB is up the chute, little else is liable given the symptoms. 😉
    Remember to power off if you decide to investigate.
    HTH
    barnacleben
    Cheers,
    Will have a look over the weekend. However, when things involve soldering in place it starts getting a bit complicated for me.
    Ben
    #248326
    karv
    9 out of 10 brand new extractors will not be faulty when people think they have problems . most likely the wire/cord as been left to long or not been cliped up out the way and has fallen down and jammed the fan blade or a bit of plaster has fallen down or something along tho lines.
    unlikey to be pcb , when u turn on and hear buzzing mean either the fan is stuck on somthing or motor is struggling ie bad motor
