Hoover
  • #58663
    zod
    Now removed
    #335227
    odom
    Re: Hoover washer wont spin even after new brushes fitted
    Were the old brushes worn? Did you check the motor armature for damage/raised segments and use a comm stick to clean armature and bed in new brushes?
    Before spending money on a new motor unplug machine and use a multimeter to check continuity of wiring from board to plug – tug all wires on motor plug to check none are loose. Check resistance through pins of motor and let us know what these are.
    #335228
    zod
    odom wrote:Were the old brushes worn? Did you check the motor armature for damage/raised segments and use a comm stick to clean armature and bed in new brushes?
    Thanks for the help.
    Yes the old brushes were worn.
    The motor armature did seem OK and not having a comm stick I cleaned it with electrical spray and a cloth.
    I will open it again and check the wiring.
    Unfortunatley I’m only an amature and dont own a multitester.
    Is there any other advice you can offer while I’ve got the back off.
    Thanks again,
