Hoover 1200 NW – All Lights a Flashin Baby ! Help !
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hoover 1200 NW – All Lights a Flashin Baby ! Help !
Viewing 14 posts - 16 through 29 (of 29 total)
  • #133212
    Ron916
    Re: Hoover 1200 NW – All Lights a Flashin Baby ! Help !
    Hi Yurtesen,
    Thanks for the reply…
    I’ll try a cold wash and see what happens. Good thinking.
    As to the lights –
    On 1 second off 1 second continuously till power off and on.
    Manual – or rather little book that came with it say nothing of troubleshooting or faults…just says call the hoover service line….
    Thanks again.
    Ron,
    #133213
    Ron916
    well just tried all the programs i could in an effort to see if any are ok but the flashing thing happens with em all…..
    Off to make some dinner…back tommorrow…
    #133214
    yurtesen
    Did you try to watch the machine and see what it is doing right before the lights start blinking? If it is taking in water, or removing water or heating etc.
    #133215
    RS
    Ron you still haven’t put the model number up, listen to Martin he does this for a living 🙂
    PS Check your email from James
    #133216
    Ron916
    Sorry Guys – Logged off last night till this mornin and that means I’m going to have to go hame at lunch and get the whole number …..
    Will sort it by 12.00….
    #133217
    Ron916
    RS wrote:Ron you still haven’t put the model number up, listen to Martin he does this for a living 🙂
    Gottcha – Thanks.
    #133218
    Ron916
    Finally ! made it home and back…
    Serial number is indeed
    A8608 3030 1176.
    Cheers in advance of any help !
    Ron.
    #133219
    Ron916 wrote:A8608 3030 1176.
    Ron,
    Thanks for that, OK now the machine fills as normal and then the drum turns does it? Do you get only the panel lights falshing or does an ‘Error Code’ not show up on the LED display unit?
    Ron916
    Hi Martin,
    Thanks for such a prompt reply.
    Yes, the machiune goes on, program set – hit the start and the water rushes into the tray and the drum rotates. No strange noises or anything – all looks a ok.
    Then 30 mins or so into the program, the drum stops as does everything and all the LEDS flash continuosly however no error code appears on the LCD.
    Does that help ?
    #133221
    Ron916 wrote:Does that help ?
    Well, kind of 😕
    Dave may be right about the Heater being at fault except usually when that is the case it would show “E1” in the display 🙁 However it cannot be ruled out as a possible thing to check. The easy way was suggested earlier by checking your electricity meter and IF the heater was working then the meter will whiz round quite quickly as the machine was washing. If the meter didn’t at that point, its likely that is your trouble 😉
    However, the symptoms point directly to the motor and/or the connections to it. Or even dodgy contacts to the control module. None of these problems are too costly for an expert to fix for you. I would not nor could not advise DIY fixing and suggest you see if we have a recommended expert in your area by clicking on this link: –Repairs@
    Dave_Conway
    Martin wrote:Dave may be right about the Heater being at fault except usually when that is the case it would show “E1” in the display 🙁
    On the early versions (as Penguin reminded me earlier) the errors were only shown as “all lights flashing”.
    #133223
    Ron916
    Cheers for the help chaps.
    I’ll go home and do the heater test later.
    Failing that I’ll check the connections etc…I’m an Electronics eng by trade so would have thouyght myself capable with the right pointers….?
    Cheers again.
    Much appreciated indeed.
    Ron.
    #133224
    Ron916
    Too boot I just got a –
    Sorry no engineers in your area off the link anyway….
    Need to get it sorted – wife 5 months preggers and I’m of to spain saturday – Eeek –
    #133225
    Ron916
    Incidentally – I found IC5 on the panel to have some corrosion on the pins.
    I’ve ordered a replacement MM74C14N Chip and will replace….will let you know how it goes.
    It aint the heater – works fine. Also silicone sealed the drum and rubber to stop that nasty firestarting drip.
    Cheers for the advice guys.
    Ron.
