Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › Hoover
- This topic has 22 replies, 3 voices, and was last updated 13 years, 3 months ago by
Fletch316.
January 4, 2013 at 5:08 pm #73353
Fletch316
ParticipantEvening,
I’ve a Hoover hdc7fm tumble dryer which won’t heat up,i’ve bought a new heating element which i’ve fitted but there’s still no heat.Would it be possible that someone can send me a picture of the wiring connections that connect to the timer so that I know it’s wired up right.
many thanks.
picture to be sent to
January 4, 2013 at 5:11 pm #387200Jackal
ParticipantRe: Hoover
Sorry Forum rule 8 prevents this.
Jackal
Sent from my iPhone 4s using Tapatalk
http://www.lofra-uk.co.ukJanuary 4, 2013 at 6:07 pm #387201Fletch316
Ok.no picture then.
why when i’ve replaced the element there’s still no heat?
January 4, 2013 at 6:09 pm #387202Martin
Exhaust stat faulty maybe?
January 4, 2013 at 7:15 pm #387203Fletch316
Thanks Martin,where do I find this & repair if need be.
February 12, 2013 at 4:51 pm #387204Fletch316
Afternoon.
I’m having trouble with this dryer,the drum won’t go around.
it’s been fitted with a new motor so we can dismiss this.
the heat is ok but the drum refuses to turn around.any advise would be greatful.
many thanks.
February 12, 2013 at 6:35 pm #387205Martin
Belt come off or broken perhaps?
February 12, 2013 at 7:03 pm #387206Fletch316
belts fine.
February 12, 2013 at 7:13 pm #387207Martin
You said it was a new motor and that we should dismiss this. So presumably the motor is working….or is it….you didn’t mention that bit?
February 12, 2013 at 7:48 pm #387208Fletch316
a new motor was fitted late October last year.apart from it not working(maybe)how do I check it?
February 12, 2013 at 8:02 pm #387209Martin
Power off and unplugged then out with be multimeter is your best way forward.
February 12, 2013 at 8:09 pm #387210Fletch316
is it a possibility that the capacitor has gone even tho it’s a new motor?
thanks for your advice by the way.
February 12, 2013 at 8:24 pm #387211Martin
Couldn’t rule it out though if it were that you would at least hear the motor humming (trying to turn) and pretty soon smoke rising from the motor…..!
February 12, 2013 at 8:30 pm #387212Fletch316
Right,looks like I’m stripping it all down to get to the motor then.
nice job….not.
again,many thanks.
February 21, 2013 at 7:44 pm #387213Fletch316
Evening,
i’ve now replaced the motor but now I have a small problem.
The dryer now works but only on the last 10 minutes of the cooling cycle.When I put in on a normal warm cycle the dryer doesn’t work & there’s a burning smell from the motor.
i’ve recently had a new timer installed,could it be possible that they have wired it up wrong?
Many Thanks.
