Hi gents this machine will not pump out. no vaults at pump anyone had this fault or do i need a test programme or am i overlooking something cheers alro
F08 is motor related and f03 is a draining fault and this error can be thrown up with low insulation heater ive checked the model on gias and this has a brushless motor so wount be motor check the wiring to motor if that is fine and you still get f08 maybe main module
