Hoover 3761 Automatic
  • #6351
    Matilda
    Second opinion please – Just been out to this one for a mate on holiday. The fault is, it will not spin but will distribute at start of spin program 7. Mate repaired speed control module some weeks ago (burnt track) which is still ok. Module Remco 5038. Any advice much appreciated – Mat.
    #117163
    99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} module, 1{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} p/switch problems!
    cornwell40
    Re: Hoover 3761 Automatic
    Had a good few of these modules failed recently. Usually relay or dry joint related.
    Tony C
    #117165
    Simon46
    I find that if the relay contacts start arcing internally and get hot pin desolders itself from board. Only guaranteed cure is replacement module.
    #117166
    Matilda
    Thanks all I’ll check the p/s and then view a qer/emw module – Mat.
