Re: Hoover 8kg sensor dry T/D – HNV380-80 – pauses during cy
had another look at this, machine works for 5/10 minutes, then pauses. Once it has failed, the only program i can run is ‘freshen up’ which has no heat (as intended)
Any other program selected will instantly (after the briefest jerk of the drum) pause again. Makes a clicking noise.
Am ordering PCB module and sensor (one with the two skinny black wires).
will report back when i have fitted and worked out which was at fault.
