Hoover A 8754 Washer/Dryer
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hoover A 8754 Washer/Dryer
  • #28446
    internationalpete
    Hello folks,
    Just inherited this older Hoover Washer/Dryer. The drum is seized, but before it goes off to the dump, does anyone have any ideas on what I can check? I have taken off the rear panel and removed the drive belt.
    The motor does run. The drum is almost impossible to turn by hand using the large plastic(?) pulley. I have pulled this pulley off after undoing the centre bolt – the bearing does not LOOK to be damaged or burnt out, but I am guessing that this is a sealed bearing – perhaps this means nothing?
    I have pulled the pump feed hose off the bottom of the drum housing, there is a green plastic ball in there ( anti-siphon??), about the size of a ping pong ball. I can feel what I think is the heating element in the bottom of the housing, but nothing obviously jamming up the drum in the housing.
    Apart from splitting the front off the housing by removing all of the clips, (looks like a lot of work) and seeing if something is wrapped around the drum, can anyone suggest any other avenues to explore? Any help gratefully received.
    Many Thanks,
    Pete
    #218392
    Re: Hoover A 8754 Washer/Dryer
    You’ve pretty much covered all your options there, with the exception of the bearings – there are two – one in the front end of the housing as well. If you can make the tub turn, it will feel very rough if the bearings are damaged. If it is just really stiff, then yes, it’s eaten something it shouldn’t have.
    Power off, of course.
