Hoover A class frost free
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Hoover A class frost free
  • #11319
    This is hard to descibe,but here goes–
    Fault is no operation light,no light on when you open door (not bulb) no control over temp, the fridge part is frozen solid,acting more like a freezer than a fridge.
    The only numbers i can find are on the compresser- HTK 12AA . I have found the control board which is at the top of the fridge behind the hoover sticker,the numbers on the control panel are ITW LOT 30159-CK AND CU123001 And lastley 91201739.
    I think its the control panel at fault as i removed it and knocked it the fridge light came on for a split second and if you knock it on purpose it has the same effect, faulty relay?
    Where can i get a new panel from? if its that at fault
    Steve
    #144819
    Simon46
    Re: Hoover A class frost free
    Have you checked near the salad bins for model number?
    Regards
    Simon.
    #144820
    Simon46 wrote:Have you checked near the salad bins for model number?
    Regards
    Simon.
    Hi Simon
    Well, what a star! after all this time i now know what i have!! Model number HCA 390 FFK No. 34000146 0306 0469 Type epf37
    Hope this helps
    Steve
    #144821
    Simon46
    Please dont work on the fridge with it plugged in :zap: . Unplug first. It may be worth your while to check out repairs@ on LHS of page. The engineer may diagnose /fit a recon/new board for not a great amount (if this is the fault). The good thing is the fridge is capable of getting cold still.
    Regards
    Simon.
    #144822
    Hi Simon
    Sorry, bad habits picked up from my farther (he was an electrician) he used to check live wires with his fingers!!!!
    Anyway– have used the repair facility as recomended
    Thanks Again
    Steve
    #144823
    Simon46
    :tup:
