I have an AAA160 which no longer displays the Codes. Well you can see they thange but the backlight for the LED panel does not work. Was not a problem until….machine stopped working. Cleaned the filter but no cyce will commence, there is a humming noise but no water comes into machine. Have turned it of/on/off/on and played around a bit but NOTHING seems to work. There is good water supply to the machine.
Is there some MASTER RESET procedure ? ?
Help ! the washing is piling up !
