hoover aaa140
  • #35168
    onecallpaul
    Coming up with fault 1 . Changed interlock but still the same,is it likely to be the main board or display? Cheers Paul
    #245391
    timdowning
    Re: hoover aaa140
    Have you checked for timing out problems?
    (heating, pumping, filling)
    #245392
    onecallpaul
    Re: hoover aaa140
    The error comes up before it does anything
    #245393
    Re: hoover aaa140
    onecallpaul wrote:The error comes up before it does anything
    It’s the Door Interlock then 😉
    Did you not look up the ‘Error Codes Thread’?
    http://www.ukwhitegoods.co.uk/modules.p … 0&start=60
    #245394
    onecallpaul
    Re: hoover aaa140
    As I said, I changed the interlock and the error still comes up.
    #245395
    Re: hoover aaa140
    onecallpaul wrote:As I said, I changed the interlock and the error still comes up.
    Then the Interlock failing will have taken out the TR4 Triac on the coreboard (i.e. Module) 🙁
    I’ll send you details via email 🙂
    #245396
    onecallpaul
    Re: hoover aaa140
    Thanks Martin
    #245397
    Re: hoover aaa140
    Martin,
    if there are any electronic details there please send me too…
    #245398
    Re: hoover aaa140
    baron wrote:Martin,
    No problem Baron…check your email 😉
    #245399
    Re: hoover aaa140
    :wobble: 8)
