Hoover AB130 not spinning
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hoover AB130 not spinning
  • #37922
    m3esx
    I have a Hoover AB130 that has started to play up, I changed the brushes 3 months ago and everything was ok until last week when running a heavey load of towels. On the last spin it started to make a loud whining noise which when it slowed down became a clicking noise also ther was a smell of hot varnish, I am an instrumentation service engineer by profession so I began to suspect a bearing. After taking off the back and removing the belt I found the drum rotated freely with no noise but the motor clicked when turned by hand, when I removed the brushes the clicking stopped and on feeling the commutator a section was raised slightly, I cleaned everything and reassembled, on trying the washer I found that the motor struggled to turn with a loud hum but sometimes seemed ok but noisey. I have looked back through the posts on this forum and feel that the motor as probably fried a winding but would like some confirmation on this!
    Jon
    #257129
    helo_75
    yep, you armature in the motors goosed
    not available as a spare part, but the motor complete is 06015503
    hope this helps
    #257130
    helo_75
    m3esx
    Re: Hoover AB130 not spinning
    Thanks, thats what I thought!
    Jon
