Hoover AC 110, over heating.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hoover AC 110, over heating.
  • #9484
    Are both sets of contacts on this machines, stats ‘NO’.
    It overheats on Prog 9 (40 degree wash) but works fine on Prog 3 (60 wash)
    If I turn the timer to prog 4 (40 wash) after it has overheated it advances normally.
    When the water temp is high, both sets of stat contacts are closed. When I cool them down, the outer contacts are ‘OC’ but the centre ones remain closed.
    Suspect control unit, any better ideas?
    #134242
    Dave_Conway
    Re: Hoover AC 110, over heating.
    Nope, the wiring diagram indicates one NO and the NC.
    Described as 30/90 thermostat so you’d have to assume 90 is NC.
    #134243
    That would suggest the 40/60 temps are achieved with timed heat which suggests my suspicions about the control unit could well be correct, unless there is another stat at the front of the drum?
    #134244
    hot and cold inlet hoses arn’t crossed are they??
    Kevin
    #134245
    Dave_Conway
    Just the one combined thermostat as far as I can tell, I’ll email the diagram in a bit 😀
    #134246
    kheath wrote:hot and cold inlet hoses arn’t crossed are they??
    Kevin
    No, did check those. Have asked customer to try on a 40 degree wash on the long spin cycle and it has gone through OK.
    Many thanks for the PDF… Dave. :tup:
