Hoover AC110 hinge removal
  • #5933
    Furhan
    I need to replace a hinge for a customer, the machine is Hoover AC110. The hinge is attached to the machine body with rivets. I need some advice on removing the rivets and securing the new hinge. Should I use a small drill and drill through them replacing them with screws and spring washers (square washers?) or is there an easier way to remove them?
    Fur
    #114664
    Dave_Conway
    Re: Hoover AC110 hinge removel
    Hi Furhan.
    You will need to drill the old rivets off, the new door hinge part number 97910194 comes with new rivets for refitting.
    Regards.
    #114665
    Furhan
    Re: Hoover AC110 hinge removal
    Thanks.
