Machine started making wierd noises, upon inspection of the drum and pump i came across a crucifix wedged in the pump (arent kids great) after reassembly and plugging in there is the wierd noise still, only now its changed somewhat, and i notied that there are sparks in the motor (brushes end) so out with the possi and removal of the motor (seems the only other thing it could be) stripped and full of carbon dust, cleaned it all up, my question how much of the brushes should be visiblethere is about, 1 1/2 cm showing, why is it sparking ? could it be say , the bearing that is sparking (due to some fault in the bearing) ? also, anyone know of a parts supplier in the oldham area ?
thanks
