Re: Hoover ACM11 cuts out during cycle.
Had faults caused by both the pcb and timer/selector. 9 times out of 10 you just need to change the timer/selector. Your fault does sound like it could be the pcb though. Check for low insulation and water contaminated pump first. (Its always worth putting a drip cover on the pump.)
I know its nice to know a definitive answer but on this sort of fault, if you don’t want a recall, i would price up the pcb change and just add £20 to cover changing the timer/selector as well.
(i always carry a timer/selector for test purposes now as its a nice quick job plus the timer/selectors fit a whole range of models unlike the pcb’s.)
