hoover acm15
  • #16911
    keithwilliams
    the common symptom of the timer knob rotating. i’ve checked:-
    1. motor carbons
    2. heater
    3. thermistor
    4.fitted new pump
    5.solenoids
    6.door lock works
    7. no visible fault on circuit board.
    if i set it on 60c wash it fills rotates heats then advances around to quick wash and pumps out the water before doing a slow spin.
    if you’ve any ideas i’d appreciate it
    many thanks
    keith
    #172114
    Re: hoover acm15
    I seem to remember a couple of posts from Tony at EMW saying that the timer itself is prone to failure.
    Here it is.
    http://www.ukwhitegoods.co.uk/modules.p … highlight=
