HOOVER ACM15
  • #33348
    richardable
    went to this one today to clear the detergent tube. did so but now the w/m won’t do anything except drain. which ever program is chosen the drain pump runs. if you rotate prog sel it makes no difference..just drain pump…suggestions please
    HAPPY NEW YEAR.
    richard
    #238351
    Re: HOOVER ACM15
    richardable wrote:suggestions please
    Take a close look at the Coreboard for blown Triacs 😉
    #238352
    richardable
    Re: HOOVER ACM15
    martin, is the coreboard the one at the top righthand side behind prog selector?
    richard
    #238353
    DAR01
    Re: HOOVER ACM15
    Had the same problem with an old Zanussi once,turned out to be a short circuit inlet water valve,worth a check.
    Mike
    :rolls: :rolls: :rolls:
    #238354
    timdowning
    Re: HOOVER ACM15
    Could be pressure switch stuck in safety mode. Check wiring to switch as well, maybe you disturbed the wiring whilst cleaning the detergent tube.
    #238355
    richardable
    Re: HOOVER ACM15
    thanks for info will check it out and post back.
    richard
    #238356
    richardable
    Re: HOOVER ACM15
    checked pressure switch..ok…blew through pressure pipe towards drum…ok…checked the programme selector and noticed that even when the selector was on a STOP position it still ran… sorry for this but now i can’t see the wood for the trees…
    richard
    #238357
    Re: HOOVER ACM15
    For the sake of a tenner, I’d swop the timer/selector unit – all sorts of weird things are caused by them. 91201337.
