Hoover AE130 Washer issue during Rinse phase
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hoover AE130 Washer issue during Rinse phase
  • #14354
    meggiedude
    I have a Hoover AE130 washing machine approx 5 or 6 yrs old.
    I am wondering if there is a problem with a pressure sensor system.
    It seems to wash and spin OK but will not distribute spin the washing during the rinse phase. Water fills to 1/2 way up the window then drains then fill/drains again and again without the rinse spin kicking in. Clicking is evident during the filling phase – I assume from the pressure switch, but this does not let the washer spin at all. 🙁
    To complicate things slightly with a small amount of washing and using the Delicates setting – the washer seems to work during all phases OK, the main problem is seen on the Cotton and Synthetics setting with a full load of washing.
    I have tried to clean the pressure chamber out (it was not that dirty) and this did no good. The pressure tube visually appears OK, and blowing/sucking down it produces a click from the switch.
    Is this likely to be a pressure switch issue or something else? ❓
    Thanks for your help.
    #159136
    Re: Hoover AE130 Washer issue during Rinse phase
    meggiedude wrote:Is this likely to be a pressure switch issue or something else?
    Probably the motor brushes or armature are the culprits rather than a fill/drain/pressure switch problem. 😉
    #159137
    Goatboy
    It sounds like a module problem 😕
    It’s very hard to tell without seeing the machine first-hand and that is mostly a guess.
    I’d strongly recommend finding an local expert using this link…
    Repairs@
    #159138
    Goatboy
    :wave: Hi again Martin 😆
    #159139
    meggiedude
    Gents thanks for your advise, and promptness. 🙂
    Martin, forgot to mention – I have just replaced the brushes on the washer as recently the unit would not spin at all. Since then the unit is spinning OK for distribution, washing, final spin so I don’t think the motor/armature is the issue here.
    #159140
    meggiedude wrote:washing, final spin so I don’t think the motor/armature is the issue here.
    Dodgy relay on the Timer/Module board then?
