Hello,
My trusty Hoover AE230-001 has the following problem:
-It starts to spin erratically at slow speed, when the spin speed picks up it trips the RCD on my consumer unit.
Sounds like it could be a bearing / motor having to make extra effort, however the drum spins smoothly by hand with no additional resistance.
From searching on this forum it could also be the armature failing and causing problems at higher spin speeds, does this sound likely, a new motor is around £90 which is a fair chunk of the cost of a new machine.
Thanks in advance
Ben
