Hoover agitator removal
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Hoover agitator removal
  • #6463
    I’m trying to give a Hoover clothes washer (top loading) a clean out, and need to remove the inner drum.
    But, I can’t see how to remove the agitator, which I presume needs to come out first.
    It’s stripped down as far as it can be at present, with a (fragile-looking) plastic epicyclic gearbox and a brake mechanism evident at the bottom end.
    I gather this is a common method of transmission, so there must be a fairly standard way to dismantle?
    Model A6830, made in Australia.
    Any advice gladly received!
    #117840
    I think you might have got us with this one! The only thing I can find that might give you some help was this:
    http://www.hoover.com.au
    Curiously enough, Hoover Australia appears to be part of Electrolux!
    Good luck and regards,
