hi ,this machine sometimes not taking water in quick enough and error2 coming up valves ok, pressure chamber clear but motorised selector noisy .customer says if she keeps selecting programme it will eventually do the job.will replacing this selector do the job.
Is it a problem of low water pressure? If so just pull the rubber restrictor washer and its plastic thing out of the water valve. (That’s assuming they still have them, some time since I last looked).
Mike.
