This machine appears dead, have mains power in Interlock engages. machine Dead..
I fitted a new pcb timer,only to find same fault..
This machine has a PCB timer fitted top of machine..
have 240volt postive from on/off switch feeding into pcb..but when I tested the line in plug that enters into front of pcb..positive line only has 112 volts. Negitive ok. ( on checking the wiring this line comes via another part of the pcb. through the heater and back into front of pcb.
have checked heater/water valves for open circuits all ok
has anyone any ideas please..
