Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › HOOVER AL110 – Airlock ???
- This topic has 10 replies, 7 voices, and was last updated 18 years, 7 months ago by
Redflame.
August 21, 2007 at 7:24 pm #29962
Redflame
ParticipantWent to a Hoover AL110 Washer Dryer today with a drain problem –
Not pumping – Hmm easy ! Or so I thought !!!
On cycle it has what I though was an airlock when trying to drain
(Drain pump replaced, hose replaced & sump cleared 3 times also cleared pressure system !)
to no avail – It does drain eventually but seems to “hang” for about 2 mins before draining – I have 240 at the pump & the pump is running – Any ideas ?
The drainage to the spigot under the sink is clear also…HELLLLLLLLLLLLPPPPPPPP Plz… 😯
August 21, 2007 at 7:32 pm #225326roy1
ParticipantRe: HOOVER AL110 – Airlock ???
If it’s one with the pump and filter assy check it’s not got a 1p coin stuck in the small sprigot on the pump/filter, has to be a blockage.
August 21, 2007 at 7:35 pm #225327Redflame
roy1 wrote:If it’s one with the pump and filter assy check it’s not got a 1p coin stuck in the small sprigot on the pump/filter, has to be a blockage.
Nope this is not one with a filter & the pump & hose have been replaced – It sits at the back similar to a hotpoint – & It is NOT a blockage as EVERYTHING in the WD is clean & clear (was there 2 hours scratching my head – & I don’t have much hair as it is !)
August 21, 2007 at 7:38 pm #225328Penguin45
What happens if you run it disconnected from the sink spigot?
August 21, 2007 at 8:01 pm #225329timdowning
I have seen this loads of times with this type/model. The fact that the machine does eventually pump out is fine. I assume the original fault was no drainage at all? I have never fitted a like for like pump on this model, i only change the pump end with a universal Askoll. I have never worked out why it ‘hangs’ on letting the water out but it does.
Did you fit a complete genuine pump?
August 22, 2007 at 8:28 am #225330cornwell40
Had a couple of things cause this, one being an airlock after working on the machine. Usually just get the machine out and try and give it some movement whilst its pumping out (back and forth). Dislodged the air every time and never troubles again. The other was a Candy model which refused to pump within a programme but was ok when spin alone selected. Turned out to have too long a sump hose fitted for the model. Shorter hose fitted, works fine (took a while to fathom though 😉 )
Tony CAugust 22, 2007 at 9:20 am #225331Simon46
not uphill waste plumbing is there? trying to push water up waste pipe with drain spigot underwater.
S.
August 22, 2007 at 10:17 am #225332wilf
I’ve got one doing exactly the same! going back tomorrow. have changed pump and checked for blockages I also thought air lock. I’ll let you know how I get on
wilf
August 22, 2007 at 5:43 pm #225333Redflame
timdowning wrote:I have seen this loads of times with this type/model. The fact that the machine does eventually pump out is fine. I assume the original fault was no drainage at all? I have never fitted a like for like pump on this model, i only change the pump end with a universal Askoll. I have never worked out why it ‘hangs’ on letting the water out but it does.
No changed it for universal askoll just as you do !
The plumbing – Yes it does go into a spigot but the pipes under the sink are all clear too – Once disconnected it still hangs then pumps out…Wilf – I can’t wait to find out what you do…
…I wait in anticipationThanks for the posts all 😉
August 23, 2007 at 11:21 am #225334wilf
machine was moved to temporary position whilst building work is in progress. the outlet hose was unclipped from the back of cabinet and run low through a wall to an open top outlet pipe. if I lifted the hose to purge the air its ok. with the pipe refixed to the cabinet and run into a bucket (dustbin) the water flow was very slow for the first few seconds but when the air was forced out due to water flow machine worked fine. on second test there seemed to be sufficent water weight left in the pump to purge any air that might be sucked back into the end of the hose left the machine with the customer who is altering the waste pipe arangement.
wilf
August 23, 2007 at 5:32 pm #225335Redflame
Similar set up with my customer also Wilf – Thats interesting ! Will give it a go.Thanks
