Hoover AM110 Spinning problems
Home Forums Public Support Forums General Enquiries And Questions Hoover AM110 Spinning problems
  • #63743
    folleyball
    Bit of a wierd fault this.
    Nearly every other wash the machine goes through the cycle as normal but will not spin.
    If you then select spin it will happily do it.
    Anybody had similar problems on a Hoover washer?
    #354730
    Re: Hoover AM110 Spinning problems
    two faults spring to mind
    1 not draining properly blockages in hoses filters etc
    2 there is an air operated switch that has a small plastic tube leading to a chamber if this chamber get blocked it wont spin but if you try it on spin a bit later the air has leaked out and it will work
    DDSDDS
    coin in pipe leading to the pump housing will cause this
