Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hoover AM120 express 37615986 02064050 Timer Clicks Round
- This topic has 7 replies, 6 voices, and was last updated 20 years, 8 months ago by
Pat-UK.
July 18, 2005 at 5:28 pm #10764
Pat-UK
ParticipantGood afternoon everyone,
A new one on me today, The above machine thinks it’s an Indesit, Put it on any wash cycle and when it gets to the rinse the timer clicks round and sometimes keep going and while I was there today, it went round and stopped on 1, the proceeded to do a boil wash.
Not so great as I started it on a delicate wash.
No flashing neon to help.
Pump OK
Air trap OK
Brushes OK
Heater OKAnyone ever had this problem before ??
Many thanks all
Pat
July 18, 2005 at 7:11 pm #141816BobHope
ParticipantRe: Hoover AM120 express 37615986 02064050 Timer Clicks Roun
Hi Pat.
just to ask if you done an insulation test on the heater and the motor as i have had a few of these that show strange random faults and its been down to earth leakage (but not enough to trip RCDs out).Cheers Bob.
July 18, 2005 at 7:11 pm #141817Martin
Pat-UK wrote:Anyone ever had this problem before ??
Yes!
Stepper Timer Motor problem (usually the internal locking spring fails) Part No: 91201337 I think is the replacement part number.
July 18, 2005 at 7:27 pm #141818Tony_EMW
This is a common fault on these slave timers. We’ve got them in stock at £19.90+vat inc first class post and 12 months guarantee. If you need to return to us for any reason, handling charge is £4+vat. We are happy to let you borrow one and see if it sorts the problem out. Tony EMW 0115 9652118
July 18, 2005 at 8:43 pm #141819Pat-UK
Thanks everyone, I will ring the customer in the morning and give her the good news and find out if she’s happy to part with a nice wad of cash for a machine she doesn’t like. ( i think she will)
Cheer’s will post how it goes.
December 3, 2005 at 5:53 pm #141820roly16
I’ve got a similar problem although sometimes the slave unit sticks, sometimes it rotates quickly past the off position. EMW has checked the slave and pcb and found no fault. Insulation resistance of machine is 50Mohm cold, although haven’t checked it with water hot.
Has anybody got any ideas please?
GeoffDecember 5, 2005 at 1:34 pm #141821andy2
Best thing with these m/c is to carry a spare module to try in. I have had this problem a few times and replacing the module usually sorts it. These modules (R/H top of machine) seem to be fairly standard and even look to be the same on the present models, so worth having one available as a tester.
As the motorised selector switches are an analogue device returning a resistance that varies with the selected position, apart from the switch wiper being a bad contact or damaged (due to anitclockwise use) IMO they are not usually much trouble. The switch motor is controlled directly from the module so any erratic behaviour of the switch is due to the module, so its best to eliminate this first IMO.
Andy 😀
December 5, 2005 at 9:03 pm #141822roly16
Thanks for that information Andy. Since refitting the board & slave back in the machine [3 days ago] after they were tested at EMW they have been working ok! I’m wondering if I had a loose connection on one of the edge connectors. Am waiting to see what transpires.
Geoff -
