Hoover AS110
  • #19436
    DentedPorsche
    Hiyas,
    Hopefully remembered the correct model number. 😕
    After changing the outer tub on this machine it doesn’t take in much water. Less than an inch showing in the inner drum.
    The pressure chamber has been fitted onto the new outer (after drilling/cutting out the blank 😛 ). Have even tried the alternative system on the sump hose but this just meant no water showing.
    New pressure switches and new pressure hoses have not solved the problem. Is there any way to increase the volume of water in the drum?
    Brian
    #183084
    Dave_Conway
    Re: Hoover AS110
    It’s probably the correct amount of water, this model has a recirculating pump, a bit like a Zanussi jetsystem 😉
    #183085
    aqualectric
    Re: Hoover AS110
    Checked the filter behind the plinth? Recirc. pump is useless when this is blocked or the pump is jammed. 😉
    Cheers,
    Steve.
    #183086
    effzedarr
    Re: Hoover AS110
    Had this last year, check the small hose at the rear of the soap dispencer,it goes to the tub unit. If you pull that off & it makes a hissing noise, it is probably a blocked dispencer top. Either remove & soak overnite in a solution of bleech or if the customer is flush enough fit a new top half.. Hope thats some use to ya….
    Have a good one, Chris…
