Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hoover auto-washer 800 leaking
- This topic has 10 replies, 2 voices, and was last updated 14 years, 6 months ago by
johngalls.
September 23, 2011 at 12:06 pm #65241
johngalls
Participanti had a problem a while ago when a lace got stuck in the pump and the washer wouldnt empty.after managing to empty out the water and remove the lace in there the washer started to leak as soon as i started it.
i checked everything had been put back where i had to undo jubilee clips but still get the leak as soon as i try and start a wash.
any ideas or suggestions please?
reliable repairs for washing machines in the manchester area?
thankyou.September 23, 2011 at 2:21 pm #359796iadom
ModeratorRe: Hoover auto-washer 800 leaking
Proper model number might help. 😉
There several places the machine could be leaking from, not really possible for us to try and guess, it is a matter of looking carefully. 🙂
September 24, 2011 at 11:07 am #359797johngalls
ParticipantRe: Hoover auto-washer 800 leaking
Thanks for the reply,model number on the back of washer says AC288.Had it a good few years now,bought second hand,this is the first major problem i have had from it since getting it.
guess i will have to turn it on and try and see where the leak is coming from.is it safe to turn it on with the back panel removed to see inside?September 24, 2011 at 12:40 pm #359798iadom
I cannot advise you to try and run the machine with the panels removed.
Does the machine just leak or does it flood out as fast as it is going in, does it leak at once or after the machine has been runnning a while?
September 25, 2011 at 1:27 pm #359799johngalls
it starts leaking as soon as i switch it on to start the wash.
dont think i am going to try and fix it myself,i found this website which i might try once i have a bit of spare cash to afford itAdmin edit.
Unauthorised third party link removed.September 25, 2011 at 9:30 pm #359800September 26, 2011 at 11:28 am #359801johngalls
thanks for the link,can you reccomend a reliable repair service for my washer in the greater manchester area?
the link i gave seemed reasonably priced plus it comes with a 12 month gaurantee.
if someone knows of good one out of all those on the search function i would appreciate it.(bit of a minefield for me to choose one for the repair!)September 26, 2011 at 2:32 pm #359802iadom
Send me a PM with your post code and I will have a look. Do any of the ones that come up for your postcode have the large star on the map, if so they would be the ones to go for as they are either WTA or DASA members. 😉
September 26, 2011 at 2:46 pm #359803johngalls
pm’d you,hope you got it?
September 26, 2011 at 2:54 pm #359804iadom
Replied…. forum and WTA member roly16 is your man. :tup:
September 26, 2011 at 3:28 pm #359805johngalls
thanks again!
