I have recently purchased a new HOOVER AXI 10kg Washing Machine, and keep getting an error code E22, but this isn’t covered in the manual. Can anybody help advise what this issue is please??
don wrote:Hoover E22 is generically a draining issue, “recently purchased” check installation of waste hose and check filter are the first ports of call.
Don
Thanks will try that now and will let you know 🙂
OK, so i turned the washing off, turned back on, set a spin & pump cycle, and its drained fine? I check the pipe and the drain inlet, and both where ok.
So unsure now why E22 has occurred on two wash cycles now?
