hoover board w/m
  • #77931
    clockworkone
    dyn9144dg/l1-80. can anyone tell me what causes tracking to burn out at this point.
    #403926
    Re: hoover board w/m
    Fuzzy photo but looks like the overloaded track goes to the top left terminal point?
    #403927
    clockworkone
    Thank you Martin..It does indeed go to left top term but this term is unused.This tracking is the neutral supply to board.Redid tracking and after running megger over motor and heater and checking pump. Switched back on pump ran continuously and blew tracking again when i went to switch off. Checked valves and swopped i/lock also.Would be gratefull if anyone could let me have wiring diag for this one.Paul
    #403928
    repman
    Had two of these recently caused by a short cct bridge rectifier in board in the base
    on one repaired track and replaced rectifier board fixed it
    But the second needed both boards replacing
    Good luck
    Jim
    #403929
    clockworkone
    Thanks for all the replies. Appreciate that.
