Hoover built under double oven HO7D312
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hoover built under double oven HO7D312
  • #98421
    kevinlewis
    The top oven, bottom element has open circuited. How do you remove the element? The 4 element connection protrude through a metal plate by about 50mm. The element does not slide forward to enable removal. Is it side panel removal? Has anyone got the part number?
    #472330
    would need the rest of the numbers to double check but its probably
    42817766
    kevinlewis
    Serial number is 3370158216440044
    I’ve never asked how to remove an oven element. didn’t want to waste time in the customer’s house . Thought it best just to ask on here.
    #472332
    kaibart
    42817766 is the part number you need can’t remember exactly but im sure these come out from back on the single ovens its from the bottom from memory
    #472333
    kevinlewis
    Yes, its at the base of the top oven. I’m wondering if it slides out with the metal plate which it protrudes through. I will go and have another look? Thanks for the part number.
    #472334
    kevinlewis
    I discovered that you need to slide your hand under the element , lift and push it towards the front of the oven until it clears the holes in the metal plate.
