Hoover CA 320 Special Edition
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hoover CA 320 Special Edition
  • #20443
    tflrock
    The machine is letting water in all the time. Its slow,but enough to come out of drum if left for 12 hours[both hot and cold feed] Is this easy to cure and which part do i need or do i need a pro service engineer.Any info appreciated on this CHEERS.
    #187091
    DDSDDS
    Re: Hoover CA 320 Special Edition
    have you tried turning the water off at the red and blue inlet taps.
    if not try this to determine which valve is at fault(it is only generally one at a time) if you discover which valve it is then the repair is quite straight forward,providing you can et the lid off and the part is readily available.
    mains off before playing though 🙂
    if you have any difficulties you can get an engineer through this site
