Hoover/candy HFI4015 (D/W)
  • #54390
    rocker
    Has a E8 fault showing..have put meter across supply to heater..240v showing for a minute or two, then voltage drops out..cant see any dry joints on board.. but does seems like a board fault !!..is there anything else that could cause this and need checking first. before buying new board! thanks John
    #319446
    Re: Hoover/candy HFI4015 (D/W)
    Heater relay failing under load. Solder job or buy board.
    rocker
    Thanks Chris.
    #319448
    pup
    rocker wrote:Has a E8 fault showing..have put meter across supply to heater..240v showing for a minute or two, then voltage drops out..cant see any dry joints on board.. but does seems like a board fault !!..is there anything else that could cause this and need checking first. before buying new board! thanks John
    or send it to emw @tony he does them but only if no heat fault
