Candy CDM 146S with module sited at bottom back corner of machine.
No drain pump and find the large resistor in the corner of the board is burnt out.
Does anyone know the value of this resistor please.
Many thanks does look similar but cant tell if it is doing the same job.
The blown one seems to connect the neutral side of the drain pump, dryer fan, and condenser valve to the neutral line.
