Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hoover Candy washer dryer
- This topic has 8 replies, 4 voices, and was last updated 3 years, 1 month ago by
Chris Bourne.
February 16, 2023 at 12:14 pm #101719
Chris Bourne
ParticipantHi apologies if this has been solved before but I am scratching my head and can’t find the answer.
i have a number of Hoover and Candy washer dryers that wash fine, dry fine until it finishes and the clothes come out wetter than when I put them to dry.
i have changed the board from one that is working and did not solve the problem, we have changed the pump, pcb, heater, heater sensor, inlet valve, pressure switch and still having the same issue.
hoping somebody knows what we are missing
February 16, 2023 at 2:00 pm #485776iadom
ModeratorModel numbers would help. Gunge build up in the large plastic condenser is a common cause, a bit of a pain to get at to remove and clean out.:(
February 16, 2023 at 3:18 pm #485777Chris Bourne
ParticipantThanks I didn’t post model numbers as im getting the same problem with different machines, some work some don’t with the same number.
i checked the plastic condenser tank when changing the heater and looked ok.
its strange because if you watch the cycle the clothes separate like they are drying but when the cycle is finished they are stuck together soaking wet but no water in the drum
February 16, 2023 at 3:20 pm #485778Chris Bourne
ParticipantThese are the two machines im working with currently
HBDOS695TAMCE
CSOW4853TWCEFebruary 16, 2023 at 5:10 pm #485779iadom
ModeratorStill sounds like a blockage in the condenser, not easy to see but it doesn’t take much on those machines, even a small build up in the bottom can cause problems.
February 16, 2023 at 5:47 pm #485780Chris Bourne
ParticipantThank you for your replies. I will tomorrow run a dry cycle without a water connection to see how that goes and while that’s running see if I can get further into this condenser unit
February 16, 2023 at 8:16 pm #485781iadom
ModeratorThe machine will just fill with steam if you don’t have a cold water feed.
February 16, 2023 at 9:21 pm #485782kaibart
ModeratorTake off the fan motor and clean the fins on the fan blade when it’s off use the inlet hose to give condenser a bit of a clean
February 17, 2023 at 12:27 am #485783andyjawa
Participant” dry fine until it finishes and the clothes come out wetter than when I put them to dry” So presume clothes are steamy hot so that at least proves that the dryer heater works. So that leaves other options 1) the condenser is blocked up 2) the fan blades are blocked 3) there is a fault with the dryer solenoid letting too much water through OR 4) the dryer valve is not letting any or very little water through to condense the steam which is a lot more common. 5) problem with a pcboard triggering the valve to often = excess water – never had that one but with Hoover / Candy pcb any disaster could happen!
