machine worked perfectly well until she moved house now appears not to heat just sits there tumbling heater ok no supply to it pcb looks ok pressure switch works any ideas? 🙁
check the bottom plug on the pcb, the tub, for some unknown reason has a lip on it, right next to the bottom plug, and when its moved, it pulls the plug off
its the plug for the variable temp, so it wont heat, cos it cant read it
