Hoover classica E1
  • #61456
    cornwell40
    Can’t see these in the fault code guide (too old?)
    Customer getting E1 thought from memory it was a drain time out and sure enough the pump was cutting out. They called back today and its still the same.
    E1?
    Tony
    #346250
    helo_75
    its a new wave
    and the heaters faulty
    #346251
    timdowning
    Re: Hoover classica E1
    Did you unblock the pressure chamber? Also shorten the pressure tube slightly. Oh and remove the eco ball.
    E1’s on the New Wave how I miss them!!!
    #346252
    cornwell40
    Helo wins the chocolate pig 😆 On both accounts 😳
    Heater down to earth causing problems with the fill side.
    Tony
