Re: hoover condenser dryer
iadom wrote:Posts merged, you don’t mention if the ‘apparent’ current leakage occurred before or after your attempted repair?
Hi it started tripping trip switch so i checked and found mains filter had gone and so i decided to give clean and new belt, then to my horror seen 2 loose wires come off timer 1 is blue and 1 has 2 wires white and brown, i could see where they come from by the pins showing discolouration but i don’t no which way round they should be and the machine starts up either way, the blue wire is live untill its on as i tested the wires and thats how i found i was getting a feed from earth
