Hoover condenser dryer not spinning
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Hoover condenser dryer not spinning
  • #102510
    peejay1977
    Hey all so we have had our condenser dryer for a couple of years and today it’s decided not to work.
    Basically I turn the dial to whichever setting, it beeps as normal, then when I press the button for it to start it beeps then instead of the drum starting turning I hear a hum/buzz and after a few seconds it stops and gives up. This was also accompanied by a slightly electrical smell inside the drum as my wife tried it multiple times in a row.
    The drum moves by hand absolutely fine, no more or less resistance than normal. Any ideas to start with? It feels power related somehow and maybe like a module or board is getting hot and that’s what the smell is but I’m no electrician obviously.
    thanks.
    #489240
    take top off
    switch on and press start. as you do so give the drum a push
    if it revolves let it run for a minute and open door and check for heat
    if you have heat then you have a failed capacitor on the motor. most of the time its 7uF but would need the model and serial to check
    https://shop.ukwhitegoods.co.uk/washing-machine-tumble-dryer-dishwasher-7uf-capacitor
    this is the 7uf but on hoover its real fun to get and fit
    the whole fron of the drier has to com off and your working in a space only one hand can access
    peejay1977
    electrofix wrote: take top off
    Thanks Dave I’ll have a look asap! The model is HL C8LG-80
    #489242
    typical hoover have problems getting info from model no which is why i asked for serial no as well
    have you got that ?
    peejay1977
    electrofix wrote:typical hoover have problems getting info from model no which is why i asked for serial no as well
    have you got that ?
    Would that be the – 3110084117310122 ?
    #489244
    yes its a 7uF as link above
    peejay1977
    electrofix wrote:yes its a 7uF as link above
    Thanks Dave, I think I’ll buy one just in case, they aren’t expensive, sounds like I’m gonna have fun changing it if it is this! Looking at the pic of it, it;s just 2 connectors and a screw thread presumably to mount it?
    #489246
    peejay1977
    I’ve ordered the part, also just had the top off, turned it on, waited for the buzz/hum and given the drum a push and it’s spinning fine which according to the videos online seem to suggest it’s defo the capacitor.
    As for fitting it you seemed to suggest it was fiddly, one of the videos online shows fairly easy access to a similar model, but it wasn’t the condensor version. Looking at it theres no way in from the back or sides, and the condensor mechanism seems to take up the entire base of the unit. Am I right in assuming its something along the lines of:
    Top off
    Control panel off
    Door off
    Front panel off
    And then slide a hand in between the drum and plastic condenser base to try and access it?
    #489247
    basically yes
    front panel and the front frame / bearing unit off
    as you remove front panel remove wires from door switch and dont forget to plug it back on ( been there lol )
    also as you remove frame take careful note of the way the harness runs over the frame arms. if you get the wrong the wires could catch the drum and go bang
    then you have to unplug wires with one hand from the cap and some of them are tight and have to be teased off with a small screw driver
    cap has a nut on it normally 13mm
    you need to undo this and dont drop nut or the washer and if you do make sure you either know where its dropped or find it
    a loop of string can help hold the new cap in place to get the nut and washer on
    then make sure you get wires on correct terminals
    peejay1977
    electrofix wrote:basically yes
    Thanks Dave, sounds like alot of swearing will be done haha
    #489249
    peejay1977
    I’m assuming taking the drum out to get better access is an ar$e of a job?
    #489250
    dont even think about it
    to take the drum out of one of those is a big big pain ( thats the polite version )
    done dozens of cap changes it gets easier over time its the first ones you struggle with as you learn ways to make it easier
    peejay1977 wrote:
    Thanks Dave, sounds like a lot of swearing will be done haha
    suggest ear defenders for the wife and kids
    peejay1977
    electrofix wrote:dont even think about it
    Haha thanks Dave, considering I push a mouse around a desk all day for a living I’ll swerve trying to do that!
