Hoover condenser e11 fault
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Hoover condenser e11 fault
  • #101273
    Jasonwhitegoods
    Hi.. hoping someone may be able to help me with an error code.
    Hover condenser dryer Model DX C9TCER-80
    s/n 3110105519130097
    The dryer starts fine, heats up, and errors out after approx 5 minutes with E11
    It’s hot in the drum, I’ve so far checked and cleaned the condenser, checked and cleaned filters.. airflow appears good coming from lower fan.. I’ve replaced the ntc/thermistor at the front of the appliance, and checked wiring to the ntc..
    Heater element looks fine as do the thermostats on the heater box. Done insulation test on appliance, no earth leakage..
    Now I’m lost on it!!
    Any more suggestions??
    Any help much appreciated
    Regards
    Jason
    #484133
    comes up as this
    Jasonwhitegoods
    electrofix wrote:comes up as this
    Thanks for the reply Dave, I’ll get into the fan and check.. airflow seamed fine but will check and report back
