When you press the start button often the m/c wont start. You can hear a buzz as the motor is energised and sometimes smell burning (well you know the smell a motor makes when it cant turn)….. Also when running there is a squeaking noise.
Is it most likely a knackered bearing leading to failing motor????
If so I assume it would be beyond economic repair? M/C is 6yrs old and I havent read good things about Hoover so I am not keen to spend much dosh fixing it…..
If replacement advisable I am thinking about a Zanussi TCE7227W (cant afford Miele stuff) as I have a Zanussi washer which seems well engineered. Only thing I cant understand is why new Zanussi tumblers dont have timer delay on them (I prefer to run @ night). Otherwise its £70 more for John Lewis model with timer (also made by Electrolux I understand). Or what about Whirlpool are they as good generally?
Any advice appreciated? Thanks.
