hoover condensor drier
  • #103630
    Am I missing anything
    hoover dryer 31102490 – HLE C9TCE-80
    trying to remove the drum to replace the belt
    undid all the screws and drum will not budge. Firmly stuck in the casing
    looked for more screws and cant find any. Am assuming the seal round the heater inlet is making it stick but dont know
    any suggestions ?
    suedehead1
    do you need to remove the drum to replace the belt , does the front not come off of it
    #494037
    yes the front comes off but cant get belt off the motor or replace idler pulleys with the drum in
    some of the very late ones allow the sides to be removed but not this one
    suedehead1
    is there a circlip on the drum shaft
    #494039
    on the older ones i can remember you could get this from the rear but in this one its a solid back over the bearing
    kaibart
    Hi Dave I’ve had this happen to me before the heater support I think they call it it’s what the bearing sits in is stick i had to praise it with a long flat blade screwdriver didn’t come easy though little tip loosen the motor bolts from the bottom to make the belt come off go on easier kai
    #494041
    thanks m8 will go back with a bigger screwdriver
    horrendous design, total junk in my book
    Steven
    Dave looking at the drawing with that model the side panels come off, its not the early type wrap round cabinet. So guessing once front off the belt can be attached from the side, I recall doing a capacitor on one ages ago apart from the usual 20 odd screws you should be able to access!
    #494043
    yes can see diagram shows loose sides but they are not.
    there not in the parts listing so not on this model
    I think its a gasket thats stuck where the hot air enters the rear. there is a gasket just around the oblong hole
    Going back with very long screwdrivers to see if it can prise it out. told customer it may scrap it if i use too much force but I have to find out why
    to finish this off it was the seal round the heater inlet stopping the drum from being removed
    once it got a long screwdriver down there I was able to prise if off through the hole where the heater attaches
    kaibart
    As I suspected then think I broke the circlip when I done one, at least you go it sorted mate
