Hi got a Hoover d/w HED 60/80 type CANDY7A the machine stops at various places through the cycle with the first two lights on(pre-wash & wash) according to the blurb thats a fill problem.There doesn’t appear to be a pressure problem with the water or with the E valve.Any thoughts anyone.Thanks Mack.
there is a water meter on the air break behind the the LHS panel, the connector plug needs to be cut off and wires soldered directly onto tracks to stop poor connection problems, then protect your solder joints with silicone to prevent tracking when damp. this is a brief explination of a technical fault report, not one i have seen myself yet.
hope this helps
