Re: Hoover D/W HD98E Problems – With Timer Underneath
laurenceuk wrote:Hi,
This machine has a PCB in the control panel and a timer underneath –
never seen this type before.
The problem is that the machine starts ok – empties then fills and begins
the wash but the spraying stops after about 15secs. The machine is then
silent but will continue on through the prog doing everything except
spraying the water.
All the components work: recirc motor, drain pump, heater, inlet valve –
everything.
I am pretty sure that it is this timer that is causing the problem.
Can anyone confirm this?
Can anyone advise as to whether there is anyone who can repair or
exchange as they are very expensive – they come as a timer/PCB
combination?
EMW don`t do them.
Laurence
Hi Laurence Did you nail the problem with this?
