Hoover Dishwasher
  • #62133
    daviddonk
    My dishwasher recently stopped working and looking underneath i notice i have a melted Capicitor on the motor. Looking online i can get one to fit my model for £12. Is this likely to be the only problem or would it be the motor as well. I can spin the motor by hand
    #348866
    Re: Hoover Dishwasher
    Hi David,
    Yes, probably just the capacitor. What rating is it as that seems a bit expensive, could be right enough but there’s usually a cheap compatible you can use?
    daviddonk
    im not sure its a melted lump of plastic with 4 terminals on it
    #348868
    Shame, it’s usually a 6/6.3µF or a 4/4.3µFone and those are usually considerably cheaper than the genuine ones.
    daviddonk
    Just removed it and it says its a 4uf +- 5{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}
    420v ~ 10000h/ class c
    470 v ~ 3000h/ class b
    Spoke to maplin they do hundreds but one not with those voltages wondered if u had any idea
    #348870
    Yeah, that 4µF one from the link above will work just fine.
    daviddonk
    Hey i went to a white goods repairer and got the capacitor and replaced it. but the machine wont turn on. I have checked the control dial and all looks ok and the fuse is ok. Would it be the suspressor on the machine or am i in for a lost cause
    #348872
    Something has probably caused it to pop then. The trick now is finding out what and why it won’t power up.
    Trace it out, mains in, power switch, door switch…
    A meter and a little patience is required.
