Hoover dishwasher code
  • #103700
    dopper
    Looking for E40 code on hoover dishwasher 32901523230 HDIH 2T 1047-80, fills for about 5 secs then abort and E40 code
    Paul
    #494238
    Remind me in the morning to look at this please as it seems that the GIAS site is broken and has been all night.
    dopper
    Hi Kwatt here is a reminder
    #494240
    Still broken for me, I can’t get access to their system to find out what that means.
    dopper
    no problem, thanks
    #494242
    just checked site still not working
    google searched bring up flooded base but am sure you checked for that
    got one hit from a guy that fitted a new fill valve. unit worked ok with old valve ( only swapped because it leaked in) but gave E40 with new valve in. Valve was generic as he could not source original
    with that in mind the water turbine would be the place to look
    Hollytree_Technical
    I have just had a look and it turns out that I have the service manual stashed away for one of these:
    According to the manual the E40 will actually be either an E41 or E42 (in engineer mode), it talks about checking the inlet valve and flow meter.
    Not sure that I have your email address but if I have then I can send you the manual.
    Jem
